Previous Thread
Next Thread
New Reply
Print Thread
Rate Thread
#487868 Mar 7, 6:27am
New Member
New Member
I bought this 1990 Celica GTS used and all my exterior lights stay on when the engine is running except the head lights while the switch is off. Is this normal for this model?
My cluster lights are also on when the engine is running.
I checked my hand break switch is ok.
New Member
New Member
I had this problem. There is a switch behind the brake pedal that is activated when your foot is not on the brake. When you press the brake it releases the switch which activates the brake lights. After testing the switch it worked just fine. But what I noticed, where the switch touches the actual brake pedal, there was a small plastic pad that pushed into the back of the pedal that was missing. Wasnt actually missing, just dry-rotted and broken and laying on the floor under the pedal. Mine was dark green color and I saw it days before I realized the lights were staying on.
Parts were cheap and an easy fix
Good luck
New Member
New Member
I will check it topp_kat. What does the switch do? Is is grounding out or the switch is always on?
Thanks
New Member
New Member
Check out this link, https://www.monkeywrenchracing.com/...-celica-corolla-matrix-mr2-clutch-brake/
It has a picture of the part and a diagram of the location.
New Member
New Member
I checked the break switch. Nothing wrong with it and my tail lights are still ON no matter what.
Thanks
Join the conversation - Register Now or Log In to add your comment
Link Copied to Clipboard
Member Spotlight
SSCarbonGTS
SSCarbonGTS
2000 Toyota Celica
Quebec, Canada
Thank you.: www.everythingcelica.com www.aliensperformance.com
Show All Member Profiles
Recent Topics
1974 Toyota Celica GT value
by mgreen718 - Mar 25, 2025 4:40pm
Is my engine toast?
by BlueMagoo - Mar 13, 2025 6:14pm
Help!! ABS/TRC lights and codes
by idrees - Mar 11, 2025 1:57pm
Tail lights always on
by JARRISON - Mar 7, 2025 6:27am
Speaker Harness 4 Pin Part #
by brohuey - Aug 31, 2022 5:25pm
Customize Your Toyota Celica Privacy Policy · About · Contact
CelicaHobby.com is an independent Toyota Celica enthusiast website. CelicaHobby.com is not sponsored by or affiliated with Toyota Motor Sales, USA, Inc. in any way. The Toyota and Celica names and logos are trademarks owned by Toyota Motor Sales, USA, Inc.
© CelicaHobby.com, 2001-2025
Powered by UBB.threads™ PHP Forum Software 8.1.0
(Snapshot build 20250208)
